In S7 edge appearing Blue Square with sound on Display
(Topic created on: 07-14-2017 09:59 PM)
vraj98
Have you guyz encountered in S7 edge appearing Blue Square with sound #tang #tang on Display and due to this touch is stop working
5 Comments
Prince
i think you have started Voice Assistant
Believe me thats worse
you need to click on subject once & then double click to compete it.
if you want to close voicr Assistant follow this :
- Click on Apps Button (One Click only)
Then Double Click on it
- Find Settings , Click on it one time,
then double click on it.
- Swipe down with two fingers : find Accessibility
Click once & then double click on it
- do further for vesion & find Voice Assistant .
[Note : To open any thing, you need to click once on it then you need to double click on it.
if you have more then one page in apps of in apps , you can swipe with two fingers
Gud Luck🤣
vraj98
Hi,
Thanks for the replay. I have checked Voice setting and it is OFF. Could be possible Voice Assistant is getting automatically started when I put mobile in my pocket?. This really worse 😞
Prince
Not Possible i think, Check voice assistantonce one more time.
Prince
If you do not get result, my last advice is reset you phone by default settings
Settings > General Management > Reset > Reset settings.
Nothing will change but your settings will get to its default
admin_
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
