I face this problem in Oreo
(Topic created on: 06-23-2018 08:15 PM)
vishalshiv1
after update my Samsung galaxy s7 in Oreo then I face this problem every time. is any one have solution for this type of problem or any one face this type of problem too.96342f51-ea97-419f-a0cc-c5f3bfa497ef.jpg
4 Comments
RohitNawathe
That is not a problem. Go to settings and search for Block Accidental Touches and turn it off.
vishalshiv1
ok
vkv
it is a good feature to prevent accidental touch when actually you are not trying to touch phone screen. better to avoid switching on of any option or function without yout knowledge. you can turn off this from settings menu
admin_
Thank you for reaching out to the Samsung community! We would like to inform you that the issue you are facing while using the device is due to the block accidental touch is enable. Navigate to settings>>display>>block accidental touch>>disable.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
