How to use Smart View Feature in Samsung S6 edge
(Topic created on: 05-25-2017 04:42 PM)
Rahul67
Smart View Feature connects to what kind of TV's (Smart tv only??? ) and how does it connect??
Can it connect to laptop also?
6 Comments
vamsi3666
it connects to smart tv and Google's chromecast devices. Your phone and your smart tv or chromecast device should be on the same WiFi network
admin_
We're glad you reached out here with your concern. We would like to inform you that connect your device and a TV to view the device’s content on the larger screen. You may be able to use more features depending on the connected TV. Kindly check mentioned steps to connect device with TV:
1. Turn on the TV and place your device close to the TV.
2. Open the notification panel, swipe downwards on the notification panel, and then tap Search phone and scan for nearby devices.
3. Tap QUICK CONNECT.
4. Select the TV. The list of features you can use with the TV appears.
5. Select a feature and follow the on-screen instructions to use the feature. Available features may vary depending on the TV.
• View device on TV (Smart View): View your device’s content on the TV screen. You may need to activate the Screen Mirroring feature on the TV depending on the TV you want to connect. If the TV does not support the Screen Mirroring feature, use compatible accessories to enable the feature. Compatible accessories include Home Sync and an All Share Cast dongle.
• Use as remote control: Use your device as a remote control for the TV.
• View TV on device: Watch TV on your device’s screen. You can continue watching TV within the allowed connection range.
• Play TV sound on device: Listen to the sound via the device’s speaker while watching the TV. You can connect a headset to the device so that others do not hear the TV sound.
• Register TV / Deregister TV: Register the TV to your device to use additional features, such as Use as remote control.
arpit8
any phone can connect to windows 10 using Cast (Samsung Mirroring) . if you are not able to connect problem is with your phone software
dhanrajp
does smart view can be used on laptop ?
AADI27
HOW TO connect
Babushona
can we connect Smart view with laptop
