How to improve battery life on samsung s22
(Topic created on: 05-04-2022 11:25 PM)
Rohanbait
How to improve battery life on samsung s22 it's too much bad battery backup experience
3 Comments
RanitKhan
This video is based on One Ui 3.1 but most of the things are same as One Ui 4.1
So you can follow it...
I'm following since One Ui 3.1 and I'm getting much better battery life...
Just skip the steps in which that specific feature is useful to you...rest follow...https://youtu.be/o32KO_fDQVs
cs_member8
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
You can maximize the battery backup by following a few points :
● Make sure that your phone is completely charged whenever you charge it. To get the best out of your battery.
● Make sure, Wifi is turned off when not in use.
● Turn off GPS when not in use.
● Turn ON the Power Saving option in settings.
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device issue:https://www.samsung.com/in/support/mobile-devices/ways-to-maximize-battery-backup-in-samsung-smartph...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
yashrajora
Does the steps helped?
