How to enable Samsung's Pause USB Power Delivery feature ?
(Topic created on: 07-13-2023 09:01 AM)
swap55555
Guys is it available for india or more importantly is it available for s22 plus please answer ?
14 Comments
Onuu7
Auto stop charging?
swap55555
No bro pause usb features you found in game booster it's help to draw phone power directly from charger rather then battery
swap55555
Do you enable it bro
Yes. I have it on my ZFlip 4. But dont play games so much to use it.
swap55555
Thanks man for the help
swap55555
Bro enable it great features helps in Google map and android auto also
It doesnt work for apps. Only for games. I tried adding netflix, maps in game launcher but that did not help
swap55555
Ya bro done it myself also not work for apps they should allow it work with apps also
