Rohit_Gaikwad
03-30-2021 09:02 PM in
please share your suggestions if its possible by good lock or any other method welcome
Solved! Go to Solution.
Sidhabhi
03-30-2021 09:39 PM in
There is no official way, you have to try some 3rd party apps..(personally I won't suggest)
4 Comments
Ehsank
03-30-2021 09:10 PM in
No you can't change it by inbuilt system or by goodlock and also not by app ,few apps in playstore but those apps will change full status bar
Sidhabhi
Dr_Interchupipi
03-30-2021 10:19 PM in
Only possible if you root your device
Rohit_Gaikwad
04-01-2021 11:17 AM in
thanks for your suggestion . rooting is not a solutin
