High battery drain after updating to Jio true 5G in S 20FE 5G
(Topic created on: 01-11-2023 07:31 PM)
Šunil
I observed significant decrease in battery consumption after network change from Jio LTE+ to True 5G. Anyone else had this problem?
21 Comments
GuessMyName
We are yet to receive 5g SA update 😞
Šunil
Which device?
GuessMyName
M42 5g.
Šunil
By Mid Jan all devices will get. And most of the 5g devices will get without software updates. Network providers are roiling out slowly
Ujjawals
It will be because your phone will be capturing high data transfers
Battery drain will be common to all 5g activated devices
Šunil
Maybe you are right 😑
Sachin8365
How u get 5G signal in S20Fe and which sim. 5G will consume more battery and no battery saver will work if u on battery saver then it will became 4G.
Ujjawals
While using internet via mobile data, battery drain will be fast
I am using Jio and yesterday night 20fe 5g models got corrected via complaint which i made with them multiple times
Šunil
Surprisingly that is right. so there is no point of power saving in mobile. Just data on and off will work for battery saving
