almarzooqi03
05-11-2025 05:49 PM in
How to find clock face in good lock, i have s22 ultra.
Rahul_Radhakris hnan
05-13-2025 11:15 PM in
To find and customize the clock face using Good Lock on your Galaxy S22 Ultra, follow these steps:
Step-by-Step Guide:
1. Open Good Lock
Download or open the Good Lock app from the Galaxy Store (not the Play Store).
2. Install LockStar or ClockFace Module
Scroll down to the Makeup section.
Tap on ClockFace (if it’s not installed, tap to download and install it from Galaxy Store).
3. Open ClockFace
Once installed, open ClockFace from within Good Lock.
You’ll see two tabs:
Lock screen
Always On Display (AOD)
4. Choose Your Preferred Clock Style
Select either Lock screen or AOD based on what you want to customize.
Browse the available clock styles and tap to apply the one you like.
5. Customize Further (Optional)
Some styles allow further customization—tap the pencil/edit icon to tweak colors, positions, or elements.
6. Apply the Clock Face
Once customized, tap Save or Apply and it will be set on your device.
Step-by-Step Guide:
1. Open Good Lock
3. Open ClockFace
Lock screen
