Help
(Topic created on: 09-16-2024 05:01 PM)
Aryan0007
Hello,
I recently received the 6.1 update for the S23 Ultra. I would like to know if anyone has installed it and experienced any issues after the installation.
Thank you for your time.
5 Solutions
Ak_Rocks
Are nahi bhai karle
Ak_Rocks
Animation khatre level ke smooth hai
Ak_Rocks
Nahi dost check kia to thore heating kam hai pehle se aur battery thora jayada Backup de raha hai
Starbug
Fingerprint sensor is slow after the update.....
If you like and find my comment useful then please click on the 3 dot menu on my comment and accept my solution.
goodthings
Update your's device and don't bothered. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
17 Comments
Ak_Rocks
Are nahi bhai karle
Aryan0007
Thank you Bhau Battery drain waigere ja bhi issue nahi haina
Ak_Rocks
Bhai yaar solution mark kar dena 3 dot pe click karke dost!!
Ak_Rocks
Not applicable
120hz toh pehele e smooth tha , abhi or bhi?
Ak_Rocks
Bhai refresh rate nahi animations ka baat kia
Not applicable
oh haan . my bad. Maine bhi notice kiya even 60HZ main bhi bohot improve kiya animation main
Ak_Rocks
Aryan0007
Ok Thank you brother 🙏🏻
