shakira786
01-14-2024 12:16 AM (Last edited 01-14-2024 12:38 AM ) in
Could someone kindly explain to me what the battery usage and screen on time graph means.
Whats a good battery life and whats a bad one?
What do i need to look out for?
Where can i read up about this to better understand
2 Comments
itsjustJay_R
01-14-2024 01:05 AM (Last edited 01-14-2024 01:06 AM ) in
The battery usage graph illustrates which apps and processes are using your device's battery over a specific time period. It also allows you to identify power-hungry apps or services.
You should look out for high consumption apps, identify apps consuming a significant portion of the battery, and consider optimizing or limiting their use. Your screen on time depends on usage patterns, 4-6 hours of screen on time per full charge is often considered good.
Remember that battery life can vary based on device models, usage patterns, and installed apps. Regularly monitoring and optimizing your device's settings can contribute to better battery performance.
>You can access battery settings in device care in Settings
> You can do a phone diagnostic in the Samsung members app and check if your battery life is good.
>You can also check battery tips on:
https://www.samsung.com/latin_en/support/mobile-devices/tips-to-improve-the-battery-performance-of-y...
*If you are experiencing battery degradation
you might need to replace your battery at a Samsung store or through your carrier/ service provider.
shakira786
01-14-2024 03:32 AM in
Many thnx
