Resolved! Solved
Help - Reset Query for S24 Ultra
(Topic created on: 09-17-2024 01:28 AM)
HarpreetMakol
Hi All,
Are there any differences between the HARD/FACTORY RESET performed through phone's Settings menu VS the Factory reset done by pressing the volume and power buttons?
Looking to make the phone in Original/Brand new condition....
Many Thanks :)
Just go to google app add your account go to account settings delete old account no need to factory reset
10 Comments
No
HarpreetMakol
What No?
No diffrences just all your data will be lost
HarpreetMakol
It will make the phone in brand new / showroom condition? I just want to bring the phone in brand new condition, as such there is no data in the phone, I set up the phone with undesired Google account so want to set it up now with new Google account
HarpreetMakol
Should i go with Factory reset or is there a way that I can set up my new device with new Gmail account now?
HarpreetMakol
Let me try this route, as I was trying badly to remove my old google account/details from my new phone....as I will be using the Old Google account with the old phone only..
Here go to add another account then delete old one1726522828520.jpg1726522828552.jpg
goodthings
After a major update reset factory data with backup is essential for your's device to better performance. Then as you like. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
