Heating issue minimal use in s24 ultra
(Topic created on: 4 weeks ago)
Rahulllyy
Does Anyone facing heating issue in s24 ultra while using youtube and Instagram Kal tak to sab sahi tha aj patani kya ho gya Sala 1 lakh spent karo tbhi bhi yeh **bleep** samsung karta hi hain
10 Comments
Istayhere
see that **bleep** on your post.
Inko pata hain kis level ka gaali khate hain pichle 3 4 saal se
De3pak
SevenWaves
Hi there..
If network is not good, then it will drain the battery charge like hell.
In such case, for time being, on the aeroplane mode and carry on with only Wifi ON mode. Meanwhile nowadays everybody communicating and calling almost with WhatsApp.
Once you reach back to regular good network location, then turn off the aeroplane mode.
Also,
Try restarting your phone atleast once in a week to avoid energy loss
coz any power hungry apps might be stuck draining out the battery abnormally, causing overheat.
Even while at regular usage, best thing is to open only one app at a time unless any important multitasking is going on..
Latest 4K displays too are power hungry and best to use the display not more than 15-20% indoors.
Hoping your issue will be solved soon.
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
KrishhNa7
After updating mera bhi Bina kuch use kiye ho raha hai
Rahulllyy
Bro knsa model hai?
KrishhNa7
S24 Ultra 512gb
KrishhNa7
Me 19 ko update kiya uske baad se aggressive heating dekh raha hu mughe phale laga normal hai usage k karan ho raha hoga members app khol k dekha sab k sab same chiz spam kar rahe hai 🥲
