HOW TO HIDE INCOMING CALLS/REPOST
(Topic created on: 03-29-2020 03:03 AM)
Sidhabhi
NOW A DAYS, PRIVACY IS VERY IMPORTANT ASPECT..(BECAUSE OF SECERET LIFESTYLES😂🤣/JUST KIDDING)..
SO MOST OF THE USERS KEEP ON ASKING THAT 👇👇👇👇👇👇👇👇👇👇👇👇👇👇
ANDROID 10/UI2.0 HAS ONE FEATURE CALLED ""MINI POP UP""
HOW TO ACTIVATE::
Go to call Settings>Click on Call Display While Using apps>Now Select Mini Pop Up
NOTE: THIS FEATURE WORKS WHEN YOU ARE USING ANY APPS..IF YOUR SCREEN IS OFF OR YOU ARE ON YOUR DEVICE HOMESCREEN THEN THIS FEATURE WILL NOT GONNA WORK..
SO, GUYS NJOI YOUR PRIVACY
S10+
12 Comments
Aashish
Expert Level 4
What if we don't have the number saved?
let's ask Samsung this. 🤣
Hualngo
It also enables us to drag around the mini call pop up
@Aashish,then it won't solve your actual need..agar save ni hoga number to ye mini poup me number hi show karega..check below screenshot
Not applicable
Ye chewing gum jaisa feature rakhe kya aachar daalna hai.....isse acha call blocking for unknownn nos. ka feature laate to acha hota
No, bro..waise to ye feature sahi me achha hai..kyunki aap most of the time apna device me apps check karte rehte ho..aur is feature se ek to call mini pop up me aata hai aur dusra jinhe privacy chahieye unki help bhi karta hai..ha is feature ko without apps bhi chalna chahieye tha..
Not applicable
Yes is feature ko without apps chalna chahiye tha...privacy while using apps is a good thing but if you talk privacy i think Samsung has to work on Unknown Caller blocking and unknown Messages too...since people don'thave to rely on 3rd party apps like true caller
Absolutely..much needed feature
Aashish
Expert Level 4
Blocking Unknown Callers feature is already there since times immemorial.
Call Settings -> Block Numbers -> Block Unknown Callers.
