Gap between display and frame - s24 base model
(Topic created on: 09-22-2024 06:12 PM)
adi30995
There is a gap between the screen and the frame at the bottom right on the S24 base model. I checked in the store, and it's only available in the 128 GB variant. Is this gap acceptable, or should I be concerned about a defect?
13 Comments
adi30995
It depends on the variant. The gap might be present in different locations. I haven't checked that yet.
Did some research check here
https://www.samsung.com/uk/support/mobile-devices/there-is-a-gap-between-the-screen-and-frame-of-my-...
adi30995
Okay thanks
adi30995
Okay
optimistak
It's with mine 256gb Variant as well..also check it will be on left side center as well. Samsung is now screwing it's Customers...
