Galaxy S7 and S7 Edge - How to Disable VoLTE
(Topic created on: 01-03-2018 09:25 PM)
assist4tech
How do I disable VoLTE on S7 and S7 Edge. Not able to find switch to turn it off in Connections or under Phone settings.
Irritated with constant call drops and loss of network. Need to disable it.
10 Comments
saltaf
With the december update patch of today, there is VOLTE calls switch in connection settings.
assist4tech
Thanks
Addyzaccount
I am curious as to why you need such option.
assist4tech
Since it's activation been facing call drops, loss of network connectivity, most people find my phone out of coverage area. These problems did not exist earlier. Btwn I am on Airtel VoLTE in Karnataka
Addyzaccount
I see. Well Airtel VoLTE is recently implemented in Samsung phones if I am not wrong, while Jio VoLTE was already supported. The option you want might be available in Developer options or something but I suggest switching to a different carrier like Jio.
admin_
Thanks for being with Samsung and for sharing your query. we would like to inform you that unfortunately, there is no such settings are available for Volte. Be sure to hit ♡ when you find an answer that works for you.
Addyzaccount
I think with December patch such option is available. Go check it.
assist4tech
December patch solved the issue
shubham3573
I also have same issue please solve it asap
