Frame drop in Slow motion - S21 FE
(Topic created on: 05-20-2023 02:23 PM)
imd_star
Hello team, I am facing frame drop issue in every slow motion video of this phone. Is there any solution for that ?
If not, I think collectively we should raise this to Samsung, if still they do not help, we can file consumer complaint (collectively) to pressurize the brand to fix this issue on priority.
6 Comments
Wrecker
I am facing the same issue...
The issue is so annoying
cs-member11
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Clear camera application data.
Settings >Apps >Camera >Storage >Clear Data.
* Reset camera settings
Camera > Settings > Reset settings > Reset.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application>Support>Type your query>Ask a question/Tap an error report>Send)
shreyasrk05
Hi @cs-member11, none of this solution is working. So in this case, will we get a replacement of our device if our device is just a month old?
imd_star
Yes for me as well none of these solutions worked.
SrvGodara
Beginner Level 4
This is really pathetic Samsung.. you can't even address a common issue .and release a fix for it.. clearly Samsung silicon is responsible for it..
