Resolved! Solved
Fonts and background issues in Samsung S21 FE 5G
(Topic created on: 2 weeks ago)
Kartik30
After updating my Samsung S21 FE 5G to Android 7, several UI issues have appeared over the past few days:
1. Notification background – The background in the notification panel is distorted, making it hard to read the text.
2. WhatsApp messages – The background and font color in WhatsApp chats are affected, reducing readability.
3. Home screen app names – App names on the home screen appear blurry or poorly contrasted, making them difficult to read.
4. Copied text visibility – When copying text, the background and font colors seem mismatched, making it hard to see what has been selected or copied.
Is anyone else facing these problems? Any suggestions or fixes would be appreciated.
3 Solutions
科技猎手
Turn off high contrast font in settings for font issues
somanath_sahu
科技猎手
Now restart phone for solve other issue
9 Comments
科技猎手
Kartik30
Thank you so much. It worked!
科技猎手
Accept as solution please
Kartik30
Yes
科技猎手
Accept as solution on clixkon 3 dot
somanath_sahu
科技猎手
Soham30
cs_member8
Dear Samsung Member,
As you are facing multiple issues on your device, kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve the issue.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
