Fingerprint not work properly in s23 ultra
(Topic created on: 04-28-2023 02:51 AM)
sr31
Dear all
I have recently bought s23 ultra and in this device fingerprint not work properly when I open any app.sometime it read sometime not.even though I have updated many time my fingerprint in settings.
5 Comments
You using any screen guard !! check whether the tempered glass is compatible with ultrasonic sensor or not.
sr31
I am using samsung original screen protector bought from samsung website only.
Syed_Khalid
Even if we brought in Samsung website we have to make sure it is working with ultra sonic fingerprint. Ultra sonic finger print is high level finger print like even if our hand is oily or wet it will work but it will not support most of the screen protector.
JEEVA777
1. Turn on touch sensitivity in settings if you placed tempered glass on your phone. Touch sensitivity is under Display settings.
2. You can also Add index finger to unlock. It has no complaints. I'm also using it.
cs-member11
Dear Samsung Member,
We at Samsung understand the severity of the issue and apologize for the inconvenience caused to you and will surely assist you regarding the same. Would request you to kindly perform some basic steps which should resolve the issue.
If your fingerprints fail to unlock the phone, and you are asked to type in the lock screen password, follow the steps to resolve the problem:
Have you check your fingers:
Ensure that your fingers are clean and dry.
Note: 1: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
2: If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
Clean the fingerprint sensor:
Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize fingerprints.
Remove fingerprint and set up fingerprint again:
Remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up your fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
Please follow the below steps:
1). Remove the fingerprint and add a new fingerprint.
2) Check for Software Update using the steps:
Settings >> Software update >> Download and install>>Check for software
update >> If Software update available>>Download>>Downloading
updates>>Install now.
3).Please reset all device settings using the steps"
Apps>settings> general management>reset all settings
Factory data reset: Reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
Kindly create a data backup of your device via the smart switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Remember the google password before resetting the device because it is required during the initial setup.
If you do not remember then advise to reset (Forgot password) the google account.
For this; Open Gmail (https://accounts.google.com/servicelogin)>>Select forgot password>>Select "try another way" like mobile number, security question, etc.>>Select Next>>Enter a new password>>Tap on Next.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
