Fingerprint is not working properly.
(Topic created on: 09-27-2024 01:18 PM)
Rohit_jdee
I am using an S23 FE and am experiencing a recurring issue with the fingerprint sensor. Whenever I attempt to unlock the screen using my fingerprint, it often fails to recognize it. Out of every five attempts, it only works once. Can anyone suggest a solution to rectify this problem?
11 Comments
hdonivS
Did u drop your mobile on floor or rammed it on wall?
Rohit_jdee
No
Did you install or changed your tempered glass recently?
Rohit_jdee
Yes i removed tempered glass but still not working properly
Even if re registering it is not working then check with service centre
Are you using your fingerprint position properly? Maybe you can change your fingerprint position again.
Rohit_jdee
Changed it to every possible position but still it's working once in 5 times
AGalaxyuser
Remove your fingerprint and register again.
rita111
Your phone's warranty is not expired so I will suggest to visit the service center
