Fast Charging Not shown on screen
(Topic created on: 07-14-2018 12:22 PM)
Pratty
When I connect my phone to charger its first show charging then after 1 sec it reconnects and shown cable charging..Please anyone tell me is it a software issue or hardware??
12 Comments
saltaf
try changing usb cable.
Pratty
Bought new charger..but same issue
saltaf
check whether fast charging is enabled
Pratty
Fast cahrging is also enabled
Joemon
Doesn't look like a software issue, anyhow I'll recommend a factory reset. But I guess the problem is with the charging port of your phone. Contacting the service centre would be the best option.
Roger01
same issue happened to me 2 weeks ago. then after a week the device says that Moisture Has Been detected on your charging port. So i visited the service center then they replaced my usb port. now its working as new so its a hardware issue.
Pratty
Thanks alot
Pratty
Do you know the price for charging port
Roger01
my phone is in warranty so i don't know the price sry
