Facing latency issue in navigation panel
(Topic created on: 05-08-2025 07:32 PM)
SuSanT2882
Hi ,
I had just shifted to s25 from s22 and got One UI 7 out of the box. It is mindblowing in all aspects but is that any one faced an issue regarding notification panel latency for data. Means while turning off the data mobile data icon is still in on state while in network bar the data is off.
It is minor but still confusing about lagging.
Kindly try to solve this issue.
#SamsungS25
#OneUI7
2 Comments
cs_member8
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
