Face recognition problem
(Topic created on: 05-11-2022 01:29 AM)
Hassanahah
Face recognition not working properly fix this
Also finger print scanner
7 Comments
Are you using a. Screen protector which is covering those areas?
Hassanahah
I'm using white stone dome glass but it's not covering the front camera and face recognition doesn't work properly I don't know why , I've been using the stonedome glass protector since the Note 8 and I have it on my note20ultra it's works perfectly with no issues at all , but since I bout the s22ultra I'm facing these problems, face recognition and finger print not working correctly some time its works sometimes not I end up using the pattern to unlock the phone..
Hi,
Have you tried removing the existing fingerprints and face and adding again? Does it work?
Hassanahah
I tried multiple times also same problem that's weird.. I don't know if it's an issue with the device itself or not because my friend using same screen protector with no issues 🤔
I will advise you to visit nearest samsung customer service.
Please Check Your Face Recognition And Finger Print Scanner Are Up To Date Or Not
stoikiy
Having the same issue, did u solve it?
