#face recognition Problem
(Topic created on: 07-26-2020 07:54 PM)
Tittokoshy
Why samsung s10 lite face recognition doesn't work sometimes?
#samsung #samsungs10lite
5 Comments
Hi, Try to disable and re-enable it.
You can do this under Face unlock settings of your phone.
When you disable the feature, make sure you restart your phone before enabling it again.
If that doesn't work try to delete your face data and register it again.
Tittokoshy
hi,
thank you so much for the reply and let me try this .
Most welcome, if the issue still persist after the last two steps the try to wipe catch partitions;
Go to Recovery Mode and WipeCatchPartitions, switch off your device, then press Volume down key + Bixby key + Power button until the starts up and galaxy logo appears, scroll down using Volume button to highlight Wipe Catch Partitions and select it using the power button, then restart your phone.
Tittokoshy
Right now I didn't face any issue. incase if any problems existing I will follow-up the steps. Once again thank you 😊
Sure, let me know if you need further assistance.
