🔥 #ExploreOneUI7 Beta 1 - Power Saving Mode Gets a Boost! 🔋
(Topic created on: 12-14-2024 10:46 AM)
smasithick
Samsung is making major moves in usability with One UI 7, and the upgraded Power Saving Mode is a game-changer! 😍
Here’s what’s new:
120Hz refresh rate support even with Power Saving Mode on. No more compromises on buttery smooth scrolling!
(Note: When you switch to 120Hz Motion Smoothness, the option to limit CPU speed to 70% will be automatically turned off for optimal performance.)
🌙 Enable Dark Mode directly in Power Saving Mode for extra efficiency and eye comfort.
️ Set screen timeout to 30 seconds, saving every bit of battery.
One UI 7 is going all in with new customization options, letting you fine-tune your device like never before. 🔧💯
@SamsungMobileUS, you’re nailing it! 👏
Tried One UI 7 Beta yet? Share your favorite feature!
6 Comments
Surya230
Battery icon is smaller than 6.1🙁
smasithick
Nope. More visible than 6.1 icon.
Surya230
SeeSmartSelect_20241214_121209_Samsung Members_1000026973_1734158529.jpg1734158679589.jpg
smasithick
Icon is larger. No separate percentage here.
kundankrmahto
Worst update till now please don't update
4.7 gb update size and we r getting editing wallpaper notification widget theme 🤦 ♂️🤦 ♂️🤦 ♂️
Apple copied all features 🤮🤮🤮
Play store have already these kinds of apps within size of Mb.
#One_UI_7
#Bad_update
smasithick
Strongly disagree. One UI 7 is a bold step in right direction. 🔥 Native customization is all we need ❤
