Enable suspend execution for cached apps to prevent battery draining
(Topic created on: 03-10-2023 02:13 PM)
PrvnAR
This option saves a lot battery by killing or freezing cached apps, and I haven't faced any issues so far after enabling this!
18 Comments
PrvnAR
Go to developer options and search for suspend execution for cached apps in apps section or check this video
https://youtu.be/eUK85wt3-jYScreenshot_20230310_143504_Settings.jpg
mHappiee
Isn't it same as putting app in Sleep in Battery settings?
PrvnAR
I guess no, I can see a huge difference while enabling this compared to putting app in sleep
mHappiee
Ooo
Okay 👍
Anand_1244
Ye enable karne par kuch problem toh nahi hoga na
PrvnAR
No bro, I have enabled this last week, as of now no issues!
Anand_1244
Ye enable karne se hota kya hai ??
PrvnAR
Check the reddit link too incase if you've any doubt, I have attached on the post
MANISH0553
Nahi hoga.
