Acy109
4 hours ago in
In one ui 6.1 there was an option in edge panel to take any size or screenshot
And now when I updated to one ui 7 i can't see that option in edge panel it shows clipboard only ?
I was using that feature on daily basis
Can anyone let me know has it been removed or I can find it somewhere else ?
rƴuk
3 hours ago (Last edited 3 hours ago ) in
A new option has been added to the Edge Panel in One UI 7 called 'Smart select'. which you can find under the 'Apps' tab of the Edge Panel.
It performs all the functions like taking screenshots of a selected area, smart select, pinning to screen, copying text, sharing the selected content, creating gif etc.
