Earphone problem
(Topic created on: 04-26-2024 07:12 PM)
kishan7874
Hey! Guys need your help seriously before buying s24 ultra just a month ago i purchased jbl endurance run 2 for 1k for gaming for bgmi but unfortunately it isnt supporting my device please help how to fix it is it a bug?
Look its this error
Please help me asap
11 Comments
AtikShaikh
Its having Type C Port or a USB Port
kishan7874
S24 ultra has type c and the earphone has 3.5 mm jack
vajul
Have you checked the type c to 3.5 mm convertor with other devices? It maybe the convertors problem
kishan7874
Bro have tried everything it works like charm in other devices but not in this
aditya1612
Which theme are you using bro
kishan7874
Did you like it? Its called Minima
aditya1612
Can you also tell me the wallpaper name and source
kishan7874
Source of wallpaper is app :- backdrops
aditya1612
Can you tell me the wallpaper name and the source where you download it
