Double tap wake up in S9 Plus device
(Topic created on: 04-03-2021 05:48 PM)
Sharif3101
Double tap wake up function is not available in Galaxy s9 Plus. Can anybody help on it? It was a great feature and i want to enable it.
17 Comments
Actually it's not available in your device and nothing to do with the UI version..
samsungsupport1
Hello, for the S9, double top to wake up is not available but you can turn on hard press home button. Settings > search for hard press home button then turn on. Once turned on, if the screen times out, you just have to press and hold the home button to turn on the screen. Cheers!
Sharif3101
Thanks for your reply. Now i know the reason. I will wait for One Ui 3.0 for my device instead of using third party app.
Bro,your device is not eligible for UI3.0,second with UI3.0,double tap to turn off screen was added,double tap to wake up was available from longtime
Sharif3101
Where is the wake up feature? I am unable to find it.
Not applicable
Open settings
Click on advance features
Then select motion and gesture
There is available
Double tap to wake up screen
Not applicable
If helpful accept as solution by clicking on 3 dots of my comment
Ehsank
You will have to use app from playstore for this purpose as this feature come with android 11 one ui 3
Not applicable
Bro double tap to wake up available since a long time
