Does having the provided McAfee antivirus enabled drain battery in S9+?
(Topic created on: 06-13-2018 08:44 PM)
Suchitha
If it does, how do I disable it?
3 Comments
Prosenjit89
no
GalaxyTeam
S9/S9+ Indian Telegram Group
https://t.me/joinchat/DvvVrkv68WqCvOYpsUfxDA7c6fb136-4fa3-411c-ab57-13f9f1a4db7f.jpg
admin_
Thanks for being with Samsung and sharing your concern. We would like to inform you that every application in device will consume some amount of battery and you can disable the application by navigating to Settings >> Apps >> Select the App >> Force Stop and Disable. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
