Does S23 Ultra camera lens protector affect picture quality?
(Topic created on: 05-07-2023 12:21 AM)
ameal
I went for trekking. I clicked some pitures. I was not happy with it. Canera lens pritector was installed at that time.
10 Comments
user963
Expert Level 4
Yes
Yes..
GhoshAnubhab
It depends on the quality , i use it also, no problem in photo, only problem in using flash, creates a lot of lense blur
ameal
Did u compare photos with camera lens protector and without?
GhoshAnubhab
Yes, my friend and I have the same phone, and a minimal change is there in photo quality, but this is understandable to compromise this little for the satisfaction of protection, but this is also true that our camera glass is hard enough, no need of lens protector.
mukki123
There is a advice from Samsung kindly don't use any camera protector on lenses.....
It can damage your lenses.....
And I am also recommending you not to use camera lens protector if you want to take good photos.
S23 Ultra has already good protection in their lens.
ameal
Can u paste the advice or link?
Which link or advice?
S23 Ultra lens glass is strong but if you care it.
