Resolved! Solved
Display problem
(Topic created on: 01-26-2020 09:54 AM)
NehalDon
Guys i have own galaxy s10plus and today i notice my phone display misbehaving any suggestion what i have do. My phone showing greenish flicring on bottom side only.i attach a short video of display problem
My phone is in warranty condition
5 Solutions
S25ULTRA512GB
visit service center
Bro, visit nearest service center and get it checked asap..I am also using S10+, but not facing this issue
harrysidhu
screen broken from bottom
isharadsharad
visit to nearest service canter asap👍
Sumit_kmr
go to service center as soon as possible
7 Comments
S25ULTRA512GB
harrysidhu
Not applicable
seems to be display connector plugin issue...immediately go to service center
isharadsharad
Sumit_kmr
Samsung_Support1
Hi there,
Please follow the below mentioned steps in order to resolve the issue:-
1) Adjust the brightness of the device then check (Settings > Display > Brightness).
2) Run the device in Safe mode and check the issue.
3) Disable the " Show Screen Updates" option in developer options via- Settings > Developer options (If its available & highlighted) > Show Screen Updates.
4) If issue still persists, create data backup and reset the device.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
Regards,
Team Samsung Members
