Display problem
(Topic created on: 09-03-2022 08:24 AM)
kisna1
Samsung s20 plus there two green line appear on screen any solution for this
5 Comments
SujeetPathak
Go to service centre bro they will help you and replace the screen free of cost. If this line appear only software problem
savanzeel
You go first customer care and register your complaint customer care will help you and customer care all person are friendly behavior
Aziz786
Visit service center of samsung and get it replaced free of cost if ur device is under warranty
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Maheshup
Samsung is giving free replacement if u r cell pass all tests. Please go to the Samsung service centre. I did the same way.
