Display problem
(Topic created on: 12-02-2021 12:54 AM)
SAahmed
Never do a software update for s10 lite in this days, recently I've updated my phone after updating it my display is flickering and color of display got light so don't update your phones . It's not only with my phone some of the other models of Samsung phone are same issue facing
10 Comments
CAzad
Nope,
My device works perfect after every update.
SAahmed
That's great I hope it works fine in future updates too. But in my case it's not fine
Deepthipendyala
Even am facing the same issue.. Dunno wat to do.. Its so annoying..
SAahmed
Is it In warranty or not??
Deepthipendyala
No.. It started after the new update
SAahmed
I'm facing the same here
rathumar
Yeah I'm also facing the same issue, worst behavior of samsung
rathumar
Charge port not works properly
cs-member13
Expert Level 4
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
How to adjust the brightness:
Please follow the below steps
Step1: Navigate to app's screen and tap on Settings.
Step2: Tap on Display.
Step3: Adjust the brightness.
A factory reset, also known as a hard reset or master reset, is an effective, last-resort method of troubleshooting for mobile phones. It will restore your phone to its original factory settings, erasing all your data in the process. Because of this, it’s important to back up the information before you do a factory reset.
There are lots of reasons why you might want to Factory Reset your Samsung device. Whether you're giving your phone to someone else and you don't want them to access your information, or maybe you're having trouble and need to start from scratch. Factory Resetting a mobile device is not reversible. Please make sure all of your information is saved to a backup somewhere else before attempting to reset your phone or tablet.
In case the issue still occurs. Please visit the nearby service center they will check the issue physically.
