Display Problem?
(Topic created on: 09-26-2019 01:59 PM)
Vishnu_Pv
Im experiencing this kind of wired issue. Do you guys have the same issue? Is this the wallpaper problem or display? What do you think guys? My devices is S9+
9 Comments
Not applicable
it is wallpaper problem it's common nothing to be so serious about this one change your wallpaper time to time .
Vishnu_Pv
ok thanks bro.....
babi07
I had s9 working fone brother once go to service center
Not applicable
it's normal it isn't a big issue
Not applicable
and dont keep the display in maximum brightness. do use the auto brightness feature .
Not applicable
normal things...it's because of animation of wallpaper..set another wallpaper you can notice another background area blured effect...it's because of animation of differnt wallpapers ..don't worry same to all devices
S_Kumar73
it's due to amoled screen burn. it will recover but not all the time.
tejabala
bro its software recorded amoled burn cannot record on software
makn99
the theme is transparent theme...home screen wallpaper is reflecting in the background. its normal...just see if previous pages are reflecting in all present pages....if not it's just fine.
