Display Problem S23
(Topic created on: 11-22-2025 11:23 PM)
BiTtUS35
Beginner Level 3
November Patch Update Display Problem S23 Pink Line Aa Raha Hain.
6 Comments
ign0ut
Service center jao agar koi physical/Liquid damage nahi hai aur device 3 saal ke andar purchase kiya hai to free me replace hoga bs labour cost(₹649) pay karna hoga.
Mera bhi replace hua aaj hi.
BiTtUS35
Beginner Level 3
Ok Thanks Brother
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for replace/repair it's. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member8
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Kindly restart your device.
● Update software on device: apps screen > Settings > Software update > Download and install > Download > Install now.
● Reset the device:
Note: Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite. Remember Google password before resetting the device because it required during initial setup. If you don't remember the password, then reset (Forgot password) your google account.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > Factory data reset (This will erase all data, including files and downloaded apps.)
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Asik16
Update karne ke kitne time baad pink lile aaya?
