Control panel (center) and bixby home in oneui
(Topic created on: 01-29-2021 05:57 AM)
silverskull
Hi
Can you please change control center and notification panel I have to swipe twice to manage control center
and add Google feed integration to all your devices Bixby home is too cluttered
and annoying.
12 Comments
Notadeveloper
Google feed is there oneui 3.1. Stay tuned for updates in your device
silverskull
Is there any changes in control panel(center) I don't like to swipe twice for it I know I can swipe with my two  fingers but I have to use other hand to hold my device I think it would better and easy to use phone with only one hand if they do some changes.
Notadeveloper
You can get one swipe for opening quick setting fully using a good lock module named quick star
Good lock app > Quick star star module . If you dont have good lock app download it from galaxy store
You can see this option in screenshot open quick panel directly enable it.
You dont have to swie twice
silverskull
I don't want install any third-party application i want default or they can add option or they can add option in setting.
Thank you for help !!!🤗🤗
Notadeveloper
Its not third party, its Samsung own appliancation named goodlock. You can search for app in galaxy store. No problem in privacy. Its by Samsung team if privacy concern. Actually it has many things which is useful. Do check it out http://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.goodlock
Notadeveloper
Hey wait a sec, your device is M series, then no good lock. You could post it in M series threads instead of S series. It was a bit misleading for me, that i understood you were using an s series
silverskull
yes, I don't own s series device but my older brother have it, Sometimes I use that device for Spotify and other things. and I own m01 (basic phone) but control center in all Samsung phones is nearly same have toogle it by swipeing twice. its not misleading after all all device has same os some features may not be added in other devices
Notadeveloper
No M series is running Oneui Core not the full. Oneui. Even A series lack some stuff which is present in s series. S series you get full oneui with dex and many other features
silverskull
You mean its not an android
What is it then ? OneUI , Oneui is just a android skin not an OS. both (oneUI and core) are android skin.
Just Samsung didn't added those feature in core because of lesser ram and weak processor. If good lock isn't third party app why they didn't preinstalled on their devices
