Connectivity problem
(Topic created on: 01-04-2022 09:45 PM)
satio
Really horrible mobile data connectivity problem in my s21...today it strucked regular intervals...
6 Comments
Please check ✔ software update
SuRRealSaGar
Expert Level 3
Did u tried another Operator sim
Durgeshkapoor
Yes this is a problem in s21 ultra mobile data gets stuck and upload sign is shown in the Lte arrows.then I have to toggle airplane mode off-on and mobile data starts working again
Not applicable
Same here
cs-member13
Expert Level 4
Dear Samsung Member,
We apologize for the inconvenience you are facing. We understand your concern and will help you resolve this. Kindly follow the below steps to resolve your issue:
Check device network mode settings
Please follow the below steps.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend to set device network mode as LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Step4: Tap on Network operators.
Step5: Select automatically.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
Step6: Tap on OK.
Step7: Registered on network.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
cs-member13
Expert Level 4
We acknowledge your query and apologize for the same. To resolve your device network issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
