Charging issue
(Topic created on: 08-22-2025 09:45 PM)
kishan7874
I am using s24 ultra since 2 weeks i am noticing an error where when i charge my phone it charges bit slow than usual but it charges
However whenever i charge and use my phone it was the same speed of charge but since 2 weeks i noticed while using phone it charges 1% in 3 minuts in 45w charger please help me samsung
Warranty is over extended warranty is on
13 Comments
Abhirx
45w charger issue hai...consistent 45w nhi de rha..
kishan7874
Bhai charger change kar liya fir bhi same issue
Abhirx
Software issue h fir..kvi kvi maine v notice kiya h...mere tab ka to salon ne fast charge band hi kr diya h
kishan7874
Reset bhi kar liya device fir bhi same issue
Abhirx
Wait for updated ya fir ui8 pe shift ho jao
kishan7874
Bhai mai ye chiz one ui 8 pe he notice kiya i thought beta bug hoga so connect kiya cable and computer and smart switch se downgrade kar liya so phone also formatted and came back to one ui 7 stable
Abhirx
Bhagwan bhala kare fir..
madan1976
Same problem 🙏
goodthings
Kindly charge your's device in cool atmosphere also turn off internet during charging also reset all settings in general management settings also flight ✈️ mode on and off one time also optimize your's device in device care too also clear cache of all apps manually also update your's all apps too then try to it's again. If you like please accept it as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
