Charging Problems
(Topic created on: 06-12-2024 07:17 PM)
Sentient
I just plugged in my phone and it's not charging. I restarted and I started charging bit after a while it stopped. I have a samsung 24+. I'm so confused on why.
10 Comments
Are you using the original charger ?
Check sitting of battery.
Sentient
I was using the original wire
Sentient
Now I switched to another wire bit the battery doesn't seem to go up at all
Sentient
All this is activated. I plugged it into my friends Motorola charger and it's charging now
Sentient
I believe it's this plug i got as a freebie with the phone
Looks not good🤝
Sentient
TraverS
Bad plug. Buy a Samsung one or atleast good ones with high watts charging capacity. 25w and above.
