Charging Problem
(Topic created on: 10-13-2019 09:00 PM)
TyrantRj
5 Comments
Møňū
water drop detected.
please don't put this
Advise to use new charger nd cable
Mukesh4sam
Let it dry,have patience , because all The IP68+ devices have this precautionary message. If you had dip your phone in chlorine or salty water , clean it with fresh water and pat dry . you can use cotton buds or straw to take out water from the port . If immediate charging is needed, I'd suggest better not to as it would damage but if it is urgent ,switch off the phone and it'll charge ;) , use wireless charger if available .
(P.S. :The precautionary message may last for a day)
darsh1
just wait and let it dry naturally. your phone will be fine after 3 to 4 hours. no worries
Not applicable
use wireless charging rather using wired charging
Not applicable
it's been a years since Samsung introduced wireless charging system from s6
