Charging Problem
(Topic created on: 10-26-2022 07:32 PM)
SreeHarsha
Why in S 22 ultra after UI 5.0 and Android 13 update Superfast Charging changes to normal Charging any ideas or is it a bug?
3 Comments
potatoKun
Try swapping the port you insert into the phone . What I mean is, Insert the usb end, which is inserted into your charger, into the phone. And the end you insert in phone, put it in the charger.
Also, I am not sure about S22 ultra. But, what i have seen is in s22 , if battery temperature is above 34 °C , fast charging stops .
Hopes it helps
SreeHarsha
Will check it shows Super Fast Charging 2.0 and within min it changes to Charging mode earlier it never happened
anirudhmp
It's a bug
