Resolved! Solved
Charging Issue
(Topic created on: 11-24-2025 10:54 AM)
Prabhu_3
My S23 Stops Charging after few seconds I plug in my charger. What maybe the issue & anyone knows how to resolve it? ( Already tried restarting , Software is upto date)
goodthings
Kindly go to service center for check and resolves this issue. If you like Please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
8 Comments
Tojirz
Beginner Level 3
Check your charger cable and adapter. Maybe it's damaged and needs replacement. Try charging with other charger.
Prabhu_3
No, checked some stuff on YouTube and turned off all battery related settings and tried charging then works fine now.
Tojirz
Beginner Level 3
Oh, that's good to know.
RUIII
goodthings
Prabhu_3
Checked some stuff on YouTube and turned off all battery related settings and tried charging then works fine now.
goodthings
You're welcome.
goodthings
You're welcome to here.
