Can we flash indian firmware on korean model
(Topic created on: 09-13-2023 02:04 AM)
HetalB
Im having s22 ultra korean model. I want to use it in india but it was purchased in korean have apps from there and calender app and same samsung app are in korean. Samsung pay also not work
So can i flash indian firmware on my korean s22 ultra?
Both indian and korean model have snapdragon just i see differences are in 5g bands. Korean has only 2 5g bands.
4 Comments
abhinavkrpcse
Use it as it is- recommended as,
It will void warranty. And may cause system breach also while installation leading to corruption of files and may lead to crashing of features or os. It will also cause internal issues certainly.
It will be a risky task to change firmware.
HetalB
Thanks sir
GalaxyF12user
S series and A series from 2022 has different model number in different region...like A34 has A346E in India and A346B in Europe and other region alse has other numbers...you can flash a firmware that has same model number...if korea and India has same model number you can flash it..
HetalB
Ok then its not possible.
Thanks for help
