Camera setting not opening issue and battery draining fast in new mobile
(Topic created on: 07-15-2022 07:19 AM)
Members_51DQ22w
Camera setting not opening after i update device this is just one month old device less used and want to tell  i never face issue like this even in cheaper chinese mobile and I'm very disappointed after spend huge amount of money in device for poor interface I'll never buy samsung in future and I'll record screen and publish on social media ... That samsung mobiles worthless , i feel nothing new in s20 fe why so costly only for processor this like same as m31s and other cheaper samsjng mobiles so why we will buy these costly mobiles really feeling bad 😣
And also battery draining very fast last 5 percent alive for only 2 minutes even in mobile data off mode .
Plzz fix battery and camera setting error as soon as possible or ill publish screen record
Bad experience 😕😕😕😕😕
5 Comments
pilotsandeep
May be you have installed any third party app which is causing battery drainage issue and failure of camera setting. Please see any third party app u have installed and uninstall the app and check it once .
Or put your device in SAFE MODE and see if you are still facing the issue .
Check this it can help.
Clear the data of your camera app.
Or check in safe mode
Or restart your device
Reset your device and Backup your data before reset
s20 fe me call recording nahi hai kya
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
