Camera issue battery issue heatung issue one ui 8 update
(Topic created on: Saturday)
adityarathod16
Recently recieved my s24 fe on 25th of september .. camera is turn bad now downggraded HDR control very bad face turning too much oily and unnecessarry details visible whixh are not visible in reality.. back Camera got worse after update.. camera is the only thing why i bought this **bleep**.
Battery draining fast when using camera and instagram
And heating too much while chrging for no reason
Back camera
Front camera
11 Comments
Kaustav_Ray
Expert Level 3
Your S24 FE’s recent update likely worsened the camera processing. Roll back if possible, clear camera cache, or try a factory reset. High battery drain and heating are tied to intensive apps like Instagram and the new camera processing.
praveenrajn
Camera looks like oppo cam😂🙏
praveenrajn
I downgraded my device to 6.1 and now am Happy everything fine
How to downgrade
praveenrajn
On pc, samfw for firmware and odin for flash. And you can backup data on smart switch
U also noticed that downgrade in one ui 8??
praveenrajn
Am on oneui 7 and its battery backup and everything worst and heating. October i will get oneui8😂i dont want to worstest situation to my phone. So i downgraded oneui6.1 is ok ok stage
Does this void warranty
praveenrajn
Maybe yes
