Call screen problem
(Topic created on: 03-07-2021 01:35 PM)
Thej745
I started having this issue after I updated my phone to one ui 3.0
I am not getting caller image on my caller screen.
Can anyone provide me a solution to this problem?
9 Comments
Ehsank
did you set and not showing?
Thej745
everything is in the default settings
Ehsank
perform these below steps one by one and observe
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect with pc/laptop or type c earphone only for Android 11 )
...........OR.......
IF YOU HAVE ANOTHER MOBILE THEN CONNECT WITH CABLE WHETHER IT IS TYPE C TO TYPE C OR MICRO USB PORT take help of otg connector to connect with other mobile.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
(NOTE : Reset settings/ Reset App preferences, change all settings to default)
XpantherX
well i have seen one of my buddy have the same problem and even more the read caller id aloud option wasnt working
Sanskar
does that contact have its image saved??
Not applicable
In Android 11 update
if the caller image was not set it shows like this only
it's not your device fault
Samsung just changed that
That's it
Thej745
so i have to set image for each contact?
Not applicable
Exactly
Samsung_Support1
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
