CALLER FIELD PROBLEM
(Topic created on: 12-23-2024 12:18 PM)
yahooiamhere
Please change this.Please solve this problem.Please unvisible the section.Could you solve this problem in next update?@samsung
4 Comments
Kris21
If the call is attempted afterwards it is visible before that while ringing it is not visible Add call & Mute options
CodingNET
Hello yahooiamhere!
The invisible part (grayed out) of the caller field requires the call to be connected first after then you can use those options. This basically means that those options need the receiver to be on the line.
Mark us as solution to keep getting wonderful solutions on your every post
cs_member8
Dear Samsung Member,
As per your query, we would like to clarify that the situation you mentioned is not an issue or bug, but rather a feature of the device's design. Unfortunately, we cannot make the caller field section invisible as it is integral to the device's functionality. We appreciate your feedback regarding this matter and will take it into consideration for future updates.
If you have any further questions or need additional information, please feel free to reach out.
