Blur engine not working correctly in S25 ultra
(Topic created on: 05-04-2025 04:07 AM)
Adipanzer
As you can see in the image, the bur applied to the calendar widget is not working correctly and the clock widget blur is working fine with nice amount of blur applied, where as the calendar widget is simply see through.
It happens most often after wallpaper changes.
2 Comments
scamsung-user
Samsung ️ Scamsung
cs_member8
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
