Big Problem
(Topic created on: 02-03-2022 06:31 PM)
Dinesh8600
Beginner Level 4
Recently I noticed that while my phone rings the sound is too low. This is because while ringing, only the bottom speaker of my stereo is working. But while choosing the track for ringtones the sound is loud as it fires from both speakers.
If there is a moderate noise in the house, I won't be able to hear the call from the other room.
Can this be fixed with a software update?
2 Comments
Gopalk
I am also facing the same problem
Datta_PK
I have also same issues. It happened after UI 4.1 update. Earlier both speakers were working fine in incoming call notification.
Still do you have this problem ?
