Battery
(Topic created on: yesterday)
sandip6619
Battery consumption so more than ui 6.1 in UI 7 PLEASE DO SOMETHING SAMSUNG
5 Comments
sanu2313
Clear all cache from recovery mode. The bug will be fixed.
sandip6619
How can I do it please tell me bro
THES3AN
To clear the cache on a Samsung device using recovery mode, you need to enter recovery mode by pressing and holding the volume up and power buttons simultaneously. Once in recovery mode, navigate using the volume buttons to select "Wipe cache partition" and confirm with the power button. This process will remove temporary files and data, potentially improving device performance.
Yes
goodthings
